Message |
There is a 12V circuit that runs into the dash for the bulb, I believe it's white/red wire. runs into the bulb check relay and then to the actual bulb. if either the relay or the bulb is not working the alternator will not charge. if you have the bulb out of the socket it will not charge, if the bulb is blown it will not charge, if the bulb is LED it will not charge.
